Help Will not lose root
azazel
So Im running a rooted Bell Atrix. Rooted using S1C root method. After doing a factory reset I still have SU and root access.
Did aRoot to clean up S1C root method. Even after running unroot.bat after I still have SU and root access.
Did Vol down + power button fastboot Android Recovery. Wiped EVERYTHING, reload, still have SU and root access.
I will not lose root access or SU. What gives? lol To some this would be a good thing, but I mean... I thought we could root/unroot anytime we needed?
How many times you need to root your phone haha... idk why you bothered with aRoot after you already had root... Should use the unroot made by the same developer as the inital root method. Mix and match doesnt always work out pretty like in this case.
lol yeah I figured once is enough but I heard aRoot cleans up the S1C mess of double busybox. Just find it strange. Ah well, I guess its better than not having root.
PS. This is my first Android device so I'm kind of learning as I go along.
