Root Will ota root keeper work if super SU is installed?
If you're looking to be able to save root related to over-the-air (OTA) installations (you didn't say why or in what context you're looking to save root for--but that's the typical reason), then you might want to have a look at Chainfire's FlashFire app:
https://play.google.com/store/apps/details?id=eu.chainfire.flash
FlashFire is the most advanced on-device firmware flasher available for rooted Android devices. It can flash full firmware packages from various manufacturers, as well as apply over-the-air (OTA) and ZIP updates - all while maintaining root, and without using a custom recovery. It also offers full device backup and restore functionalities in several formats. Relevant files can be stored on internal storage, SD cards, USB connected storage, or can even be streamed directly to and from your computer using USB or Wi-Fi.
I've not actually used this myself, so I can't really guide you on it's usage, so be sure to read, read, read through all of the documentation and support links for any gotchas.
Hope this helps! :)
Yes I wish to keep root or restore it after OTA update. I learnt applying OTA on rooted phones bricks it. So I would love an alternative to disable root or possibly backup then apply the OTA then restore my root rights. Getting to root this device was very stressful and difficult. So I wouldn't want to lose my roots privilege after upgrading to 7.0.
Thanks so much bro. Am sorry for awakening this thread after years. Am downloading the app now. I will like to keep in touch with you outside here. Maybe on whatsapp or Facebook
