Hi
I've at long last got the 2.2 update from T-Mobile. I must admit I'm not overwhelmed. Perhaps the prolonged wait is the reason.
I have managed to follow guide to be able to transfer apps to SD card, but I personally find that too many of them have issues once on the SD card and I need to revert them back.
I also seem to have a problem with the sensitivity of the auto rotate on 2.2. All too often the screen shows landscape when it ought not to.
I've got 35mb of space left on internal, and it is enough really. The biggest plus for me is being able to get co-pilot onto SD without any issues.
This is my first android phone and it blows away any WM phone I had in the past. With those WM phone I did used to root them. However I always found that the ROM's created would fall down somewhere, never really to be fixed. It just felt like I was constantly having to update my ROM in the hope all would be ok. I don't have that issue with Android.
So is it possible for me to root my phone, and use the suppplied T-Mobile 2.2 ROM? (It would be nice to be able to strip out German bloatware). Or can anyone suggest an alternative?
Will that enable me to have apps on SD card that at present are problematical and need to be moved back to phone.
As I said from the beginning of this post, I have found the 2.2 update a bit disappointing
