Hello, I was just wondering about this. I am interested in how it works and would like to know if it will work with the case on. Thanks!!
the wireless charging doesn't add any bulk on the s4 that I can tell. But I don't see it being able to charge through the otter box. I would love to see a test with the charging kit and difference cases to see if it can through any of the cases.
I have the otter box defender on my phone and it charges fine on the wireless charger.
ViveAlive Special Sales Website
Do you have the Samsung OEM wireless charging back plate?
The wireless back does make the phone a bit bigger at the top.
Here is a good review:
The official Samsung Galaxy S4 wireless charging kit | Android Central
"It's not a trivial amount of extra thickness, and the differences are more than cosmetic. The S4 becomes more rounded with the new back cover, which might change the way you hold it. (In our opinion, this actually makes it a little easier to hold.) Finally, in case you were wondering, NFC still works even with the thicker back cover in place, although any form-fitting cases you might have bought likely won't fit with the wireless charging back in plate."
well finally found someone who tested one (aftermarket not the official one)
Samsung Galaxy S4 wireless charging and NFC works with cases - YouTube
and it worked through 3 cases! Good news!
Have you held one in your hand? I have. its subjective. I find it to be trivial, barely add any weight, and didn't change the way I held my phone with it on.
The biggest issue with wireless charging for the S4 is:
It charges up to 95%-100% then stops charging and once the battery drops just even 0.01%, the charging starts again.
This results in the phone making noises every time charging starts and stops.
This results in the screen turning on and off every time charging starts and stops.
This results in the pop up notification message every time charging starts and stops.
Truly annoying.
Screen randomly turning on drove me mad. Had to move the Qi pad to another room.
