Help Will this MicroSD card work in my Optimus M?
fixitpete
Member
NEW 32GB Micro SD SDHC Card+SD Adapter | eBay
It appears to be a "Class 4" based on this:
[FONT=Arial, Helvetica, sans-serif]
This is a Generic Brand Card and may not work in all electronic devices. Like some phones and older Devices. Please research your Electronic Device and make sure this chip is compatible with it before purchasing it.​
All cards have been tested for stated memory size!​
32 GB Micro SD Card Class 4 NEW!
The memory card has a capacity of 32 GB with the ability to download
up to 2,000 minutes of video, 6,000 songs or 29,000 photos!
Description
New 32GB Micro-SDHC TF Memory Card
Compliant with the SD Specification Version 2.00.
Versatile when combined with the adapter, can be used as a full-size standard SDHC or MiniSD card. Compatible with microSDHC host devices; not compatible with standard microSD-enabled device/readers.
File Format: FAT 32.
Operating temperatures: -13F to 185F (-25C to 85C).
Storage temperatures: -40F to 185F (-40C to 85C).
weight: 24 g
size: approx 15.5*10*1 mm
You think it'll work?
[/FONT]
Description
weight: 24 g
[/FONT]
yes it will work. the optimus M has the ability to handle SDHC thus a 32gb card would work. BUT, be very cautious of where you get your card. usually "generic" cards are a big no no. and especially on ebay, someone could be trying to rip people off. personally i got a ADATA 32gb class 4 microSDHC from newegg for $66, i WAS thinking of looking on ebay but the reliability is just TOO low when it comes to such a high demand item like microSDHC cards.
Look, here is the deal. I lived overseas and I know what much of what sells online in auctions because I watched people sell it. I'm not going to say that all or even most products are bad. I will say that if you find a good deal, be cautious.
Here is what I do:
  1. I take myself down to the local electronics store.
  2. I find the nearest helper and inform him or her that I want a micro SD card and ask them to point me in that direction.
  3. I buy it and I don't worry about it.
Try Fry's, they are cheap. I avoid all these strip-mall, end-user, post-consumer nonsense shops like Best Buy, Circuit City, and whatever else is going on out that. I don't even know the names of these shops. Fry's has good stuff cheap and I don't need to know about anyone else unless their stuff is (1) better and reasonably price or (2) cheaper and of comparable quality.
I would agree with alexseven on this one. Most of the people I know who have tried eBay for SD cards and the like have not had a very good experience. More often than not that "great deal" is a scam.
If you're not going to buy it from a retail store, then I would suggest Amazon. It's where I bought my card and it came in retail packaging. Using due diligence I was able to find a reliable seller.
As with any purchase online, it's best to have a buyer beware attitude. Better safe than ripped off is what I say.
Thanks for all the replies guys! I'm going to give them a try. If it sucks, it'll go back. I'm certain the guy doesn't want bad feedback. ;) I did find some on NewEgg that were pretty well priced too. :) All I know is 2GB is NOT NOT NOT enough!
