Will USB headset work on Droid?
jforum
Does the USB port on Driod support an USB headset like the one you plug into a computer's USB port?
Connection wise, I can use the charging USB cable, an USB Type A female to female gender changer, then plug an USB headset onto it. Of course this is not for mobility. I would like to use my comfortable USB headset with my Droid wile working at my home office.
And similarly, will it work on HTC Driod Eris?
Hmmm - I have a USB to stereo output for my old Logitech headset. I wonder if I used a male to male 1/8" stereo plug, then used a USB female to female gender changer, and plugged my USB headset into that....
Probably not, though lol. I don't think that the headset output is powered enough to drive that particular device.
It might be easier to get a set of 1/8" stereo to dual RCA plugs, connect that to your computer, then connect your headset to your computer. Of course, that only works when you have a computer handy with RCA input for audio....Or you could use a long 1/8" stereo to 1/8" stereo cable (male to male) to connect to your computer.
For computer-less applications, go with a BlueTooth headset - I got a set of Motorola's MOTOROKR S9 HD for ~$60 (original MSRP was $179). Well worth the investment, with the added benefit of no wires.
