PrinceCorwin
Android Expert
Anyone know if VZ S3 will get the kit kat update?
Just updated here about an hour ago. Not sure what I should be looking for. Seems a bit quicker . Hope the battery life is better, was starting to suck.
I just checked and got the update too.
Battery life is even worse on 4.4.2, and the notification tray is slower and reponds less.
You did a mistake buddy :/
I'm on Verizon and just updated. Only problem is now I got no color on the battery bar and my wifi doesn't show color either. Just like white. Other than that it seems normal and working fine.
I think I did make a mistake. Now I can't save, move, or copy anything to or from my external SD card. When I try, I get a message saying that 4.4 is unable to modify contents of sd card due to Google policy. WTF!!?
Yeah, me too. Wish I didn't update. Makes my SD card useless. Can't even delete any files from it. Epic fail Google!This is my biggest fear! I do all of the above on a daily basis...without the ability to do just that...move, copy and modify the content on my SD card...I am having a hard time imagining using my beloved device! Old school...logical (seems normal to do these things)...or am I just cranky when it comes to adjusting to change? I am not looking forward to this update.
It most likely will not get past 4.1.2
Hope you don't depend on your SD card for storagebit the bullet. decided to update. fingers crossed.
so far I can move pictures from the phone to the card without issue.
