what do you mean about the GPS?
woke up this morning to an update notification...i can't ignore it so i just delayed the update....i'm scared! it says it will automatically update next time the phone is turned off...wtf?? anyway to NOT update it?
Used to be a toggle that you could pull down that would activate the GPS on or off.
Now it has been replaced with Location. Long press location>Mode now you have the choice of high accuracy, power saving and GPS only. Extra steps now required to use GPS only. Previous to the Update the pull down toggle had a GPS only option that you turned on or off. This new way is totally ********.
why long press if you dont have to?
the SD thing is a joke.
What do you mean Dennygreen? I just hit download, with one eye closed, as I've held out because of all I've read about problems using and transferring photos between the phone and my SD card. Hoping it's not a problem...trying to be optimistic, till I see what I get once this install is done.
Google removed the ability to save or modify files on the SD card in Kit Kat. You either have to hook up the phone to a PC, or root the phone.
Thanks Mydian. I've been tinkering around with the phone since I got this update a few minutes ago. I can still view and delete images on the card from the phone, but what you just said, I have not had a chance to check out yet. I at least won't have big expectations.
Everything else seems okay....although I noticed I've lost a few keys on my keyboard symbols toggle, and as well a few things previously mentioned in earlier posts that weren't too significant to me...yet! '-)
There were some changes mentioned in the official info during the download which I haven't noticed...like losing the icons at the bottom of the lockscreen? Maybe I read that wrong...they are still there.
Thanks again.
