thequeenscheese
Android Expert
Will we get 4.1.2 or even 4.2?
Its android 4.1.2 is the next version.
It looks like its available. Paranandroid has it for the P5113, but its a hybrid.
Do you have a link for this?
Tks
Tks
Need some help ive tried to put the cyanaogenmod on the tab 2 ive installed rom manager and got a clockwork recovery going on, i wiped the dalvik cache went to install from ext sd it didnt like the rom and failed, so i went into rom manager with in the tab but it did not find the ext sd, so i then put the rom on the internal sd and ran it from within android and the rom manager, now all i get is the tab boot pic then the cyanogenmod spinning boot logo?
odin does not recognise dev nor kies either for restore option..
