you NEED to download winamp 5.59 beta on your PC...
i don't think you can get it from winamps webpage i got it from Betanews.
once you do that, go to portables on the left pane.
make sure your wifi is on your phone
you SHOULD see your phone... click on it and it will try to connect
on your desire hit acccept
go back to your winamp on PC click on connect and then it should work fine and auto connect whenever you connect wifi
yes, your PC does need to be WiFi
since the service is not looking for a hotspot, or you would be required to choose an SSID
it's like a adhoc wifi to wifi connection... not very secure but they don't have access to anything
Your PC does NOT have to have wifi. However, it must be on the same network as the phone. So they need to be connected to the same router. If your PC is connected via Ethernet to your router, and your phone connects to that same router via wifi, than it should work fine.
This is true. My PC is hardwired and my phone is connected via WiFi to the same router. I have no issues WiFi Syncing my Winamp to my phone.
I do not see an option to connect with wifi or to send the pairing message to my phone.
