Windsheild mounts
oaklane
Does anyone have suggestions for a windshield mount for Droid 3? I don't want to order the one that is specific to it as I would have to take off my case everytime and I had one of those for my Droid 1 (still have). I ordered one off of Amazon but the side grips block the usb connection.
Thanks -
The car dock specific to the D3 comes with an insert that is REQUIRED if you DO NOT have a case on it. If you have a case, you simply remove this insert then the dock is larger than the phone to make room for a case. Unless you have an OtterBox-esque case, it should fit. Go to a VZW store, test the fit, then buy from Amazon. I love my Moto dock, it's a great fit and is very secure.
