A avs Newbie Dec 15, 2010 #1 Any good ones for the cappy? I'd like to go portrait mode for GPS and it work with the cheap amazon rubbery case if possible THAnKS
sremick Android Expert Dec 15, 2010 #2 avs said: Any good ones for the cappy? I'd like to go portrait mode for GPS and it work with the cheap amazon rubbery case if possible THAnKS Click to expand... The Captivate FAQ is mentioned in the forum sticky. Have you checked there? One is mentioned. Accessories - CapFAQ
