Root WinXP users wanting to use Wired Tether app
messenger13
Android Expert
Not only will you need the USB drivers for your DROID, but you will also need to install the Remote NDIS based Internet Sharing Device drivers. These are not native to WinXP SP3 or older. CLICK HERE to download the drivers. You'll need to unzip that file, then point to that folder when XP wants to find the drivers for your Motorola A855 when you try to tether via a USB cable. Once those drivers are installed, wired tethering is as easy as plugging in the USB cable and firing up the 'Wired Tether for Root Users' app.
