it is not packed, it is called "Little Kernel" but it really is not like the regular kernel, that is packed with a ramdisk
I have tried compiling my own aboot from the CAF source, I did one with out changing anything, then I went and changed a "1" to a "0" in the aboot.c files, and compiled again, afterwards I compared the two compiled files and there were a lot of differences, and all I did was changed one little thing
Does anyone, anyone at all, know someone at LG? I've been trying everything I can think of, but until I hear back from someone at codefire, I'm at a standstill.
Also, can anyone explain what the 2ndinit is, if it is on our phone, and where I can find it?
Sooo... If I may ask, what does all that mean? In semi-noob terms please
Sent from my potato
Did you try putting this aboot on the motion, see if it throws our security error or not? If it doesn't that may be our key, we will just compile our own aboot without the added security.
BTW, I also verified that it is for sure our aboot that is throwing the error. Found the exact string with HxD
Ok, this is what I understand, I may be wrong.
Our kernel (uuh, kinda like a system base?) is based off another one called "little kernel". The kernel is stored in our aboot file. He got the sources, made a small change, and there was a lot of changes throughout the compiled program.
I believe this is the source of our phone's specific kernel Open Source Detail
LG is not going to give out there source to there aboot "Little Kernel"
and they do not have to, it is not under GPL like the Linux Kernel is
LG is not going to give out their source to there aboot "Little Kernel"
Ok, so the phone does not come with 2nd init? If not, does the bootloader have to be unlocked to add it? If not, why bother unlocking the bootloader? From what I understand, we can just make a 2nd init with our custom roms, etc.
So.. Without that private key, we are screwed?
Sent from my potato
I have tried using the 2nd init, Optimus 4X Recovery installed
the problem I encounter was with the netd file that was being replaced
"you know that Andoid OS file you replace to high jack the Android boot process"
well the LG motions ROM did not like that netd file, and would not boot Android until you put the original netd file back
If we could get some type of 2nd init recovey to work, that would be good
but ultimately we want a new / hacked boot loader so that we cab use custom kernels and such
So it is the other kernel that is there? What is the android file inside that zip?
i tried previously, im hoping january im able to get a motion, at which point im sure i could get a working bootstrap. unfortunately that is teh earliest i can say i would be able to commit to something like that
the optimus g got lucky in that the nexus 4 was so similar that even the board layout was the same. their "unlocked" bootloader allows them to unlock but no graphics in fastboot mode so they must do it blind (not that is truly horrible seeing as fastboot requires a computer).
so are they using the nexus 4 aboot ?
So, why don't we just use their unlock method?
Okay...i love that this thread is getting tons of work going on with the bootloader and all....
can someone explain to me though, in easier to understand terms, why we can't use a modded version of the optimus 4x recovery 1.0 apk? it booted me into CWM, and I was able to navigate and reboot to system...
because it is a different phone and it won't work with ours...
