Root [WIP][DEV] Custom Recovery/Bootloader unlocking Work In Progress Thread
i definately wrote to some qfuses with wallpaper, but they where at zero, and I changed them, to 22, then to 33
maybe the ones that are factory blown can not be changed
what we want is to de-compile to C which is more understandable than assembler code
I don't believe I found a qfuse that was 00 and if I recall correct some had a letter and number like c0 for example.
C0 would be hex code for 192. In hex, 1-9 are normal, then a=10 b=11, etc until f, then you would start again at 10(16)... 1a(26) ...1f(31)...20(32) etc.
EDIT: and you can tell wallpaper that any location is a qfuse and it will believe you, and keep your changes. Haven't checked if they persist through reboot though.
It kept none of my changes I checked with read after write. I'm switching service so soon I won't hold back on testing things. I will look at which qfuses held a alphanumeric value and convert it. Thanks for the tip I didn't pay much attention to them or think about it until I post it.
Thus far I can only easily break it down like this :
const unsigned char abootto264[] = {
0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd2,
0x3f, 0xc9, 0xfa, 0x04, 0x00, 0xc9, 0x52, 0x04, 0x00, 0xc9, 0x52,
0xc6, 0x3f, 0x00, 0x01, 0x00, 0x00, 0xc9, 0x3f, 0xc6, 0x3f, 0x00,
0x18, 0x00, 0x00, 0x06, 0x00, 0x00, 0xcb, 0x25, 0x28, 0x00, 0xcb,
0x2b, 0x28, 0x00, 0xcb, 0x31, 0x28, 0x00, 0xcb, 0x37, 0x28, 0x00,
0xcb, 0x3d, 0x28, 0x00, 0xcb, 0x3d, 0x28, 0x00, 0xcb, 0x54, 0x28,
0x00, 0xcb, 0x10, 0x0f, 0x11, 0xcf, 0x0b, 0x0a, 0xe1, 0xc7, 0x05
That's the first 7 lines....
I have the first 500 lines or so broke down like this but we need to know exactly what we are looking for....
edit :Here is the full aboot broken down :
https://www.dropbox.com/s/vw56lczrrayibkv/aboot.h
also in this what is the 6f? { QFPROM_DEBUG_ENABLE, 0xC1000000, 0x0000006F}, /* JTAG DISABLE */
Qfuses have a high and low value. No, high is not blown and low is not unblown, they are simply 2 values in the same qfuse. I believe the first is the high and the second is the low.
Part of our tz (trustzone) partition
Code:
ROM:00009106 sub_9106                                ; CODE XREF: sub_C33C+CCp
ROM:00009106                                         ; sub_C33C+EAp
ROM:00009106
ROM:00009106 var_10          = -0x10
ROM:00009106 var_C           = -0xC
ROM:00009106 var_4           = -4
ROM:00009106
ROM:00009106                 STR.W   LR, [SP,#var_4]!
ROM:0000910A                 MOV     R12, R0
ROM:0000910C                 SUB     SP, SP, #0xC
ROM:0000910E                 MOV     R3, R2
ROM:00009110                 MOV     R0, 0xFFFFFFFC
ROM:00009114                 CMP.W   R12, #0
ROM:00009118                 MOV.W   R2, #1
ROM:0000911C                 BEQ     loc_9152
ROM:0000911E                 CMP.W   R12, #1
ROM:00009122                 BEQ     loc_913E
ROM:00009124                 CMP.W   R12, #3
ROM:00009128                 BNE     loc_9138
ROM:0000912A                 MOVS    R0, #0xC8 ; '+'
ROM:0000912C                 STR     R2, [SP,#0x10+var_10]
ROM:0000912E                 STR     R2, [SP,#0x10+var_C]
ROM:00009130                 MOV     R2, R1
ROM:00009132                 ADR     R1, (aGspiTimer+1)
ROM:00009134                 BL      sub_BB44
ROM:00009138
ROM:00009138 loc_9138                                ; CODE XREF: sub_9106+22j
ROM:00009138                 ADD     SP, SP, #0xC
ROM:0000913A                 LDR.W   PC, [SP+4+var_4],#4
ROM:0000913E ; ---------------------------------------------------------------------------
ROM:0000913E
ROM:0000913E loc_913E                                ; CODE XREF: sub_9106+1Cj
ROM:0000913E                 MOVS    R0, #0x13
ROM:00009140                 STR     R2, [SP,#0x10+var_10]
ROM:00009142                 STR     R2, [SP,#0x10+var_C]
ROM:00009144                 MOV     R2, R1
ROM:00009146                 ADR     R1, aPpiGptSecure ; "PPI GPT Secure"
ROM:00009148                 BL      sub_BB44
ROM:0000914C                 ADD     SP, SP, #0xC
ROM:0000914E                 LDR.W   PC, [SP+4+var_4],#4
ROM:00009152 ; ---------------------------------------------------------------------------
ROM:00009152
ROM:00009152 loc_9152                                ; CODE XREF: sub_9106+16j
ROM:00009152                 MOVS    R0, #0x12
ROM:00009154                 STR     R2, [SP,#0x10+var_10]
ROM:00009156                 STR     R2, [SP,#0x10+var_C]
ROM:00009158                 MOV     R2, R1
ROM:0000915A                 ADR     R1, aPpiGptNonSecur ; "PPI GPT Non Secure"
ROM:0000915C                 BL      sub_BB44
ROM:00009160                 ADD     SP, SP, #0xC
ROM:00009162                 LDR.W   PC, [SP+4+var_4],#4
ROM:00009162 ; End of function sub_9106
ROM:0000939A loc_939A                                ; CODE XREF: ROM:00009340j
ROM:0000939A                                         ; ROM:00009354j ...
ROM:0000939A                 BLX     loc_1F3D4
ROM:0000939E                 MOV     R0, R4
ROM:000093A0                 MOV     R1, R5
ROM:000093A2                 POP     {R4-R6,PC}
ROM:000093A4 ; ---------------------------------------------------------------------------
ROM:000093A4                 STR.W   LR, [SP,#-4]!
ROM:000093A8                 MOV     R12, R0
ROM:000093AA                 SUB     SP, SP, #0xC
ROM:000093AC                 MOV     R3, R2
ROM:000093AE                 MOV     R0, 0xFFFFFFFC
ROM:000093B2                 CMP.W   R12, #0
ROM:000093B6                 MOV.W   R2, #1
ROM:000093BA                 BEQ     loc_93F0
ROM:000093BC                 CMP.W   R12, #1
ROM:000093C0                 BEQ     loc_93DC
ROM:000093C2                 CMP.W   R12, #3
ROM:000093C6                 BNE     loc_93D6
ROM:000093C8                 MOVS    R0, #0xC9 ; '+'
ROM:000093CA                 STR     R2, [SP]
ROM:000093CC                 STR     R2, [SP,#4]
ROM:000093CE                 MOV     R2, R1
ROM:000093D0                 ADR     R1, aSpiWdogBark ; "SPI WDog Bark"
ROM:000093D2                 BL      sub_BB44
ROM:000093D6
ROM:000093D6 loc_93D6                                ; CODE XREF: ROM:000093C6j
ROM:000093D6                 ADD     SP, SP, #0xC
ROM:000093D8                 LDR.W   PC, [SP],#4
ROM:000093DC ; ---------------------------------------------------------------------------
ROM:000093DC
ROM:000093DC loc_93DC                                ; CODE XREF: ROM:000093C0j
ROM:000093DC                 MOVS    R0, #0x15
ROM:000093DE                 STR     R2, [SP]
ROM:000093E0                 STR     R2, [SP,#4]
ROM:000093E2                 MOV     R2, R1
ROM:000093E4                 ADR     R1, aPpiWdtSecure ; "PPI WDT Secure"
ROM:000093E6                 BL      sub_BB44
ROM:000093EA                 ADD     SP, SP, #0xC
ROM:000093EC                 LDR.W   PC, [SP],#4
ROM:000025B8 sub_25B8                                ; CODE XREF: sub_11672+34p
ROM:000025B8
ROM:000025B8 var_20          = -0x20
ROM:000025B8 var_1C          = -0x1C
ROM:000025B8
ROM:000025B8                 PUSH    {R4-R7,LR}
ROM:000025BA                 SUB     SP, SP, #0xC
ROM:000025BC                 BLX     sub_1F3E4
ROM:000025C0                 MOV.W   R4, #0
ROM:000025C4                 MOVW    R6, #0x6C6C
ROM:000025C8                 MOV.W   R5, #1
ROM:000025CC                 MOVT.W  R6, #0x2A02
ROM:000025D0                 CBZ     R0, loc_2614
ROM:000025D2                 LDRB    R0, [R6]
ROM:000025D4                 CBZ     R0, loc_25EE
ROM:000025D6                 MOVW    R2, #0x28AF
ROM:000025DA                 MOVS    R3, #0
ROM:000025DC                 MOVS    R0, #0x14
ROM:000025DE                 STR     R5, [SP,#0x20+var_20]
ROM:000025E0                 MOVT.W  R2, #0x2A00
ROM:000025E4                 STR     R5, [SP,#0x20+var_1C]
ROM:000025E6                 ADR     R1, aPpiWdtNonSec_0 ; "PPI WDT NON Secure"
ROM:000025E8                 BL      sub_BB44
ROM:000025EC                 MOV     R4, R0
ROM:000025EE
ROM:000025EE loc_25EE                                ; CODE XREF: sub_25B8+1Cj
ROM:000025EE                 MOVW    R2, #0x28F7
ROM:000025F2                 MOVS    R3, #0
ROM:000025F4                 MOVS    R0, #0xF
ROM:000025F6                 STR     R5, [SP,#0x20+var_20]
ROM:000025F8                 MOVT.W  R2, #0x2A00
ROM:000025FC                 STR     R5, [SP,#0x20+var_1C]
ROM:000025FE                 ADR     R1, aSgiWdtReset ; "SGI WDT Reset"
ROM:00002600                 BL      sub_BB44
ROM:00002604                 ORR.W   R0, R0, R4
ROM:00002608
ROM:00002608 loc_2608                                ; CODE XREF: sub_25B8+E6j
ROM:00002608                 CMP     R0, #0
ROM:0000260A                 BEQ     loc_26A0
ROM:0000260C                 MOV.W   R0, #0xFFFFFFFF
ROM:00002610                 ADD     SP, SP, #0xC
ROM:00002612                 POP     {R4-R7,PC}
ROM:00002614 ; ---------------------------------------------------------------------------
ROM:00002614
ROM:00002614 loc_2614                                ; CODE XREF: sub_25B8+18j
ROM:00002614                 MOVS    R7, #0
ROM:00002616                 MOVW    R2, #0x20FF
ROM:0000261A                 MOVS    R0, #0xD7 ; '+'
ROM:0000261C                 STR     R7, [SP,#0x20+var_20]
ROM:0000261E                 MOV     R3, R7
ROM:00002620                 STR     R5, [SP,#0x20+var_1C]
ROM:00002622                 MOVT.W  R2, #0x2A00
ROM:00002626                 ADR     R1, aSpiXpu     ; "SPI XPU"
ROM:00002628                 BL      sub_BB44
ROM:0000262C                 MOV     R4, R0
ROM:0000262E                 MOVW    R2, #0x20FF
ROM:00002632                 STR     R7, [SP,#0x20+var_20]
ROM:00002634                 MOV     R3, R7
ROM:00002636                 STR     R5, [SP,#0x20+var_1C]
ROM:00002638                 MOVT.W  R2, #0x2A00
ROM:0000263C                 ADR     R1, aSpiTopImem ; "SPI TOP IMEM"
ROM:0000263E                 MOV.W   R0, #0x7B ; '{'
ROM:00002642                 BL      sub_BB44
ROM:00002646                 ORR.W   R4, R0, R4
ROM:0000264A                 MOVW    R2, #0x20FF
ROM:0000264E                 STR     R7, [SP,#0x20+var_20]
ROM:00002650                 MOV     R3, R7
ROM:00002652                 STR     R5, [SP,#0x20+var_1C]
ROM:00002654                 MOVT.W  R2, #0x2A00
ROM:00002658                 ADR     R1, aPpiMmssImemXpu ; "PPI MMSS IMEM XPU"
ROM:0000265A                 MOV.W   R0, #0x6E ; 'n'
ROM:0000265E                 BL      sub_BB44
ROM:00002662                 ORR.W   R4, R0, R4
ROM:00002666                 LDRB    R0, [R6]
ROM:00002668                 CBZ     R0, loc_2684
ROM:0000266A                 MOVW    R2, #0x28AF
ROM:0000266E                 MOVS    R3, #0
ROM:00002670                 MOVS    R0, #0x14
ROM:00002672                 STR     R5, [SP,#0x20+var_20]
ROM:00002674                 MOVT.W  R2, #0x2A00
ROM:00002678                 STR     R5, [SP,#0x20+var_1C]
ROM:0000267A                 ADR     R1, aPpiWdtNonSec_0 ; "PPI WDT NON Secure"
ROM:0000267C                 BL      sub_BB44
ROM:00002680                 ORR.W   R4, R0, R4
ROM:00002684
ROM:00002684 loc_2684                                ; CODE XREF: sub_25B8+B0j
ROM:00002684                 MOVW    R2, #0x28F7
ROM:00002688                 MOVS    R3, #0
ROM:0000268A                 MOVS    R0, #0xF
ROM:0000268C                 STR     R5, [SP,#0x20+var_20]
ROM:0000268E                 MOVT.W  R2, #0x2A00
ROM:00002692                 STR     R5, [SP,#0x20+var_1C]
ROM:00002694                 ADR     R1, aSgiWdtReset ; "SGI WDT Reset"
ROM:00002696                 BL      sub_BB44
ROM:0000269A                 ORR.W   R0, R0, R4
ROM:0000269E                 B       loc_2608
ROM:000026A0 ; ---------------------------------------------------------------------------
ROM:000026A0
ROM:000026A0 loc_26A0                                ; CODE XREF: sub_25B8+52j
ROM:000026A0                 MOVS    R0, #0
ROM:000026A2                 ADD     SP, SP, #0xC
ROM:000026A4                 POP     {R4-R7,PC}
ROM:000026A4 ; End of function sub_25B8
ROM:000026A4
ROM:000026A6
ROM:000026A6 ; =============== S U B R O U T I N E =======================================
ROM:000026A6
ROM:000026A6
ROM:000026A6 sub_26A6                                ; CODE XREF: ROM:000029E6p
ROM:000026A6
ROM:000026A6 var_10          = -0x10
ROM:000026A6 var_C           = -0xC
ROM:000026A6 var_4           = -4
ROM:000026A6
ROM:000026A6                 STR.W   LR, [SP,#var_4]!
ROM:000026AA
ROM:000026AA loc_26AA                                ; CODE XREF: ROM:00002B86j
ROM:000026AA                 SUB     SP, SP, #0xC
ROM:000026AC                 MOVW    R1, #0x6C6C
ROM:000026B0                 MOV.W   R0, #1
ROM:000026B4                 MOVT.W  R1, #0x2A02
ROM:000026B8                 STRB    R0, [R1]
ROM:000026BA                 MOV.W   R1, #1
ROM:000026BE                 MOVW    R2, #0x28AF
ROM:000026C2                 MOVT.W  R1, #0x4000
ROM:000026C6                 STR     R0, [SP,#0x10+var_C]
ROM:000026C8                 MOV.W   R3, #0
ROM:000026CC                 STR     R1, [SP,#0x10+var_10]
ROM:000026CE
ROM:000026CE loc_26CE                                ; CODE XREF: sub_2BA0+Aj
ROM:000026CE                 MOVT.W  R2, #0x2A00
ROM:000026D2                 ADR     R1, aPpiWdtNonSec_0 ; "PPI WDT NON Secure"
ROM:000026D4                 MOV.W   R0, #0x14
ROM:000026D8                 BL      sub_BB44
ROM:000026DC                 CBZ     R0, loc_26E8
ROM:000026DE
ROM:000026DE loc_26DE                                ; CODE XREF: sub_2BA0+1Aj
ROM:000026DE                 MOV.W   R0, #0xFFFFFFFF
ROM:000026E2                 ADD     SP, SP, #0xC
ROM:000026E4                 LDR.W   PC, [SP+4+var_4],#4
ROM:000026E8 ; ---------------------------------------------------------------------------
ROM:000026E8
ROM:000026E8 loc_26E8                                ; CODE XREF: sub_26A6+36j
ROM:000026E8                 MOVS    R0, #0
ROM:000026EA                 ADD     SP, SP, #0xC
ROM:000026EC                 LDR.W   PC, [SP+4+var_4],#4
ROM:000026EC ; End of function sub_26A6
A few secures and non-secures in there.
Found these in SBL1. They look like.. source code files?
Code:
ROM:000146B4 aHome001Hans_15 DCB "/home001/hanseog.kim/msm8960_ics_release_mpcs/non_HLOS/boot_imag"
ROM:000146B4                 DCB "es/core/boot/secboot3/msm8960/sbl1/sbl1_mc.c",0
ROM:00014721                 DCB    0
ROM:00014722                 DCB    0
ROM:00014723                 DCB    0
ROM:00014724 aHome001Hans_14 DCB "/home001/hanseog.kim/msm8960_ics_release_mpcs/non_HLOS/boot_imag"
ROM:00014724                 DCB "es/core/boot/secboot3/msm8960/sbl1/sbl1_hw.c",0
ROM:00014791                 DCB    0
ROM:00014792                 DCB    0
ROM:00014793                 DCB    0
ROM:00014794 aHome001Hans_13 DCB "/home001/hanseog.kim/msm8960_ics_release_mpcs/non_HLOS/boot_imag"
ROM:00014794                 DCB "es/core/boot/secboot3/common/boot_pbl_v1.c",0
ROM:000147FF                 DCB    0
ROM:00014800 aHome001Hans_12 DCB "/home001/hanseog.kim/msm8960_ics_release_mpcs/non_HLOS/boot_imag"
ROM:00014800                 DCB "es/core/boot/secboot3/common/boot_clobber_prot.c",0
ROM:00014871                 DCB    0
ROM:00014872                 DCB    0
ROM:00014873                 DCB    0
ROM:00014874 aHome001Hans_11 DCB "/home001/hanseog.kim/msm8960_ics_release_mpcs/non_HLOS/boot_imag"
ROM:00014874                 DCB "es/core/boot/secboot3/common/boot_error_handler.c",0
ROM:000148E6                 DCB    0
ROM:000148E7                 DCB    0
ROM:000148E8 aHome001Hans_10 DCB "/home001/hanseog.kim/msm8960_ics_release_mpcs/non_HLOS/boot_imag"
ROM:000148E8                 DCB "es/core/boot/secboot3/common/boot_config.c",0
ROM:00014953                 DCB    0
ROM:00014954                 DCB 0xD5 ; +
ROM:00014955                 DCB 0x85 ;
AquerMang, do you know how to use IDA? I don't have any experience with it, and am kinda just guessing around, hoping I stumble on something.
Ahyep. And I've been looking at the 8960 (Spirit) bootloader. Already got a couple of ideas. Just waiting for LG to send me my Spirit back. Had to RMA it after bricking it playing musical bootchains.
im actually interested in the post that yu mention they might be source files, they look like so, as if they are needed to compile only if we could get our hands on them :/
Dunno if anyone is still interested but check under system/lib for a libunlock file. Dunno if motion has it but theirs one on the l9 and the "rumored flag" is stored on the NV partition....
