Root [WIP] Flashable Custom Boot Animations.
Zephyr101
So I am now working on some boot animations for the LG Motion, I have only tried these myself on CM10 and they are the right resolution so they look great!
So far I have only done the Google play Animation and the Nexus 4 boot animation.
I will take requests on other animations that you guys would like!
So without further ado here they are!
Google Play Store boot animation
Droid Razr Boot Animation
And if you just want the Stock CM10 animation back, here it is :)
These are all so far but there will be more to come.
Enjoy ;)
So, I'm on stock, but I've been wanting to switch my boot animation for a while. Will these work on stock if i flash it? Or do i need to manually transfer & change permission? I have one that i tried but i had to unpack it and change the resolution. When i repacked it, I'm not sure retouched it right. What is the proper method?
Also, Id love to have one that says, 'Brian's Bad/as$ Motion' in some kind of boot animation. Is that what you're talking about when you say taking requests?
What I mean by requests is boot animations from other phones/ ROMs.
And I would like to think they work on stock.
Make a backup just in case
Yea, i figured that was asking a lot, lol, had to try though...
**error**
But i still have a question and that is when re-compressing these files after extracting, I'm faced with a few options, like quality options, and then 'store'. Which would you use?
Sorry, I wouldn't know what to say, I use ROM Toolbox Pro and if that doesn't work, I have to go and resize every image in the boot animation to fit our motion screen.
Enjoy ;)
GPS. link is broken.. :-\
