ninadchaudhari
What's up !
Guys this is another very experimental project ....
like the A75 root thing [which is success]
this just a plan is drawn over a paper on Air ...
here is how i think :
IF you look in the /system/etc/permissions
you can find the permissions things which sort of give permissions for the Hardware and stuff ...
i just copied the files for Compass and tried in A70 but does not work
now I think if we just try the library files we can activate the Compass !
may be from another 2.2 device ???
may be we can try get the libraries from A70 clones or may be like bruit force
try from many 2.2 device
I know this seems to be a very difficult task but just i think this is possible
Things that seem impossible may be possible
I have the Galaxy S, Galaxy tab, library files [2.2]!!
may be we can add the library files and try if it works ...
