D
Deleted User
Guest
I have modified the stock rom, tested and working well
ONLY FOR VM USA Wildfire S
Modifications:
Zipalign-speed
deodex- some space, allows theming
wifi tether (check the quick settings tab on statuspull down
added adhoc support
Looking to add:
Anything you guys want (that is possible)
Sense 3.0 lockscreen
DSP equalizer
Wipe everything, then flash this zip. It will take a long time to flash and will take a long time to boot first time. After first boot its really fast
LINK:
https://docs.google.com/open?id=0BwZZjRHl9NIJMGI1MTI3ZTEtYTk4YS00NzAwLWE3YjktMWRhZmRkODIzNTA1
Modifications:
Zipalign-speed
)added adhoc support
Looking to add:
DSP equalizer
LINK:
