Help Wipe Clean?
Settings... privacy... factory reset.
2nd way, boot into recovery... go to "mounts and storage" and choose format data.
(To use recovery, up/down volume buttons are used to navigate up and down, press the power button to go back, and press the "n" button to do the highlighted task. Only briefly press the buttons since it's easy to skip a step by holding down a button too long.)
Someone else complained the factory reset didn't work. Guess I'll quit suggesting it for the NC.
Like what files? If they're on your sdcard, you can plug into your computer and delete them from your computer.
Are you running stock? If so then you can delete apps directly from the bn.com website, if you are running cm7 then i am of no help for that information.
