Wipe- What is it
I used search to check first and did not get an answer, and all i want is some clarification on if doing a wipe is a factory reset? please do not yell at me as i did do a search and didnt find what i needed.
Thanks.
Thanks.
I believe you are referring to when you are rooted and you want to install a new rom, you have to wipe data & cache which is basically like reformatting the phone like a hard drive for a computer for a fresh install. I'm sure there is someone else that can explain if im wrong but thats my definition of it..:D
wipe = factory DATA reset. sometimes referred to as a "hard reset." If you're rooted, it should be done from the custom recovery. If you're not rooted, it can be done under Settings > SD & Phone storage > Factory data reset.
It's not a format. It wipes all user apps and data. Your android version will remain the same. The core ROM is still intact. So this is not a factory reset. it doesn't put your phone in the state it came in. In other words, if you've upgraded to 2.2, a factory data reset will not put you back at 2.1.
Like I said someone much more informed could tell you better but I tried..:D
When flashing a new ROM do I need to wipe the cache, battery stats and rotate settings? Or is just wiping the data / factory reset good enough?
thanks all I wish I was rooted is it still possible to root with the easy root is there a mirror I can get it from any help would be great I waited to long to get it and don't really want to do the downgrade method
Is that true? If so, why did my phone seem to download and reinstall 2.2 when I reset it?
Also, the Incredible has two reset options and I don't understand the difference.
