Help Wiped MIUI installed latest nightly, Touchpad won't boot
Jeffery
I had MIUI installed and decided I wanted to start using the latest nightlies. I did a factory reset, wiped system and Dalvik, then installed the latest nightly and Gapps. When I booted Clockwork still defaulted to Classic Nerd (which just reset the Touchpad after a few seconds and shouldn't be there anymore) and when I scroll to CyanogenMod I get boot failed.
What did I do wrong, and what's the easiest remedy? My apps are backed up with Titanium and I can boot into WebOS if necessary.
Did you create a backup in recovery so you can restore MIUI and try again?
The boot folder isn't very big so when I have an extra entry in moboot (Classic Nerd), I open Root Explorer and go to the boot partition and delete it before installing my next rom.
How did you install, via CWM or Acme installer? Which nightly?
I'd boot into CWM again and format cache and data under mounts and under advanced, clear Dalvik and fix permissions. Then flash the 3/19 nightly. (The 3/12 nightly is working nice for me.)
I restored a 2/28 backup of CyanogenMod which removed Classic Nerd boot option and folder. It booted with no issue. Then I rebooted into recovery, factory reset, wiped dalvik and formatted system. Installed latest nightly and it bootlooped.
I restored 2-28 again, then only formatted system, cache and dalvik cache and it booted.
I then tried to do a factory reset, clear dalvik, format system and then just install the latest nightly and bootloop again.
What is the problem?
Are you trying to install the same nightly? Not all builds are good... none are tested until someone (us?) tries them.
My point: have you tried installing other builds (nightly from another night)? :D
I tried 3-12 this morning, same thing
EDIT: I have now tried 3-12,18,19,20,21,22 with no luck. Each time I formatted data,cache,system, wiped Dalvik and fixed permissions.
Any ideas what could be causing the problem?
What's the easiest way to start over completely?
There has to be something simple you're missing. When updating the same rom, it's not necessary to format system or data, just cache and Dalvik cache. From MIUI to CM, then you need to format data.
Is your backup from 2/28 CM7 or CM9?
If it's CM9, I'd just wipe both caches and upgrade w/o gApps. If it works, install them after. Make sure you aren't flashing anything else (kernel or mods) and make sure you reboot between restoring backup and flashing your update.
If your backup is CM7, I'd upgrade via Acme installer. When it finishes, I'd wipe data and install gApps after the initial loading.
Upgrading worked, I have no idea why starting fresh after wiping wasn't taking!
Didn't wipe, restored 2-27 CM9, restarted, upgraded to 3-22 build, restarted, finally I flashed Gapps and supreme rohan 1.3 and restarted.
Everything is working fine now. Thanks for all your help colchiro, although I still don't understand why flashing wasn't working after a factory reset.
I updated my TP last night by DL'ing nightly via Goo manager. Rom Manager came up by default and I checked to backup rom, wipe Dalvik cache and accidentally checked "wipe data" (all 3 check boxes). Came up just fine, of course w/o data, so had to restore backup, and installed via RM again.
I always use "format data" (under mounts menu) in recovery when I need to wipe data, instead of "factory reset". I know I've used "factory reset" before, but prefer knowing exactly what's happening.
