Root wire trick question
Yes I finally achieved s-off,ok thanks ill try them commands ..u think the controlbear -r or it doesn't matter just try em all?
Did you successfully get S-OFF? And you should try the commands they helped me when I had a similar problem.
I've tried all the commands and nothing is happening..I've tried going into recovery but its not seeing my sdcard,really don't know what to do at this point..if anyone could help i would appreciate it
Yeah he's right I think it might be time to flash, when this happened to me I had to re flash my recovery because it wouldn't boot into recovery.
What's the problem?
Is your phone bootlooping?
What hboot are you now?
If you're soff, its time to flash
I'm stuck on the juopunutbear screen even after achieving s-off,I'm still on hboot 1.57..I can boot into recovery using sdktools command prompt but its not recognizing my sdcard
I kinda had that problem. What i did was boot into boot loader and then go to cmd and do that fastboot flash recovery or whatever it was. Then boot into recovery flash a ROM and wala. But im sure there's better advice somebody will tell u
Good advice, that's what I had to do, flash recovery, I think you could also flash the recovery through the bootloader since you're S-OFF now
Thanks..I did the command from bootloader again and it worked but everything was erased from my memory card,I appreciate u guys helping me out..so now that I'm s-off can I just go into bootloader and then recovery and flash a rom or do I need to do something else
If you haven't flashed a recovery, you need to download one and flash that first. Then go into recovery using fastboot and then flash a rom.
Yea theres a 50/50 chance or whatever that your sdcard will get wiped, luckily mine was fine :D.
