Wireless charging pad
Paul7876
Can anyone recommend a good wireless charging pad for the Note 3?
I bought the Expower receiver and pad. When used together, the connection breaks around 30 - 40 times a night.
When I use a different pad, it works fine but I'd prefer not to use this one as it has a Japanese plug and a huge adapter.
Because this pad works ok, I'm inclined to think it's the Expower pad and not the receiver
I picked up a "S Charger Pad" for Samsung at Best Buy. Been using it for about two weeks now. Charges super fast, I love it.
I use S Charger Pad on sale after XMas about $41 and Note 3 Wireless Charging Receiver Cover bought at Best Buy on sale, about $31. They are far superior than the stuff I bough on eBay for several other phones.
The OEM cover ( black or white) is very nice and a tad thicker, which can protect the camera and flash light. Take a look for yourself at Best Buy, you'll love it.
Anyone with a Samsung charging cover and Otterbox Commuter case? Wondering if the new back cover is thicker and if it is, does it fit in the Otterbox. Right now my Commuter case fits snug with the factory cover on it.
I also use the Samsung back from bestbuy
