i think it is safe to have this thread closed now imo. Thanks for all of the input guys/gals.
Blah i know its been answered and thread should die but I have another question and didnt want to start new thread.
If we get the wireless charging cover, will it work with otterbox case? Or does it have to be in contact with charging pad?
I assume it would but would like to know if i can charge with otterbox case or any other case.
great idea on the thread i'll re title it.
the problem is if you put the inductive back on there if it adds any size to the device it may not fit in the otter box.
Considering purchase of the HTC ReZound - Inductive charging is a consideration. Will the Palm Touchstone charging base work?
Hey welcome to AF.
That is a great question. I however am not sure of that answer. Here is a thread that was down pretty deep on the list you may could ask it in there and see if anyone knows. Or someone may chime in on this one.
http://androidforums.com/htc-rezound/439938-wireless-charging-questions-here-please.html
OK so i got my inductive charging back today and here is what i have found so far:
1) yes it is quite a bit thicker than the standard back
2) no it does not work with the touchstone for the palm (either the pre our the touchpad)
3) and worst of all the standard charging port no longer works once the new back is installed. I wonder if this is a software issue or hardware
Thanks for the real life experience. This changes my mind about ordering the charging back at this point, because I want to be able to charge the phone in my car, if need be. I'll wait for software updates that allow the charging port to still retain its functionality.
I opened a support incident with HTC cause i cannot believe this was intentional.
I highly suspect that Santa is bringing me a charging pad the 25th. Has anyone else confirmed that this new battery door does not disable the usb charging port? With the new cover, is the antenna as good as the original door? Does the increased thickness feel offensive? Is the fit of cover to phone as good as the original. Do they make an inductive car charger/mount?
I need reviews with pics if possible. I may yet have time to edit Santa's list if need be.
