Help Wireless charging
basically it allows you to have a wireless charging pad that you can set your phone on. There is a chip in the phone itself that, when it connects with the charging pad, will allow the phone to start charging itself, No need to worry about plugging cords or anything else in.
A few years back, this tech popped up in best buy, but it was expensive, as you had to buy the charging pad, ad then aspecific battery pack for each specific device you owned. I am not sure they are still offering this.
With google's move into this market, I have to imagine that it will be only a matter of time before every new phone on the market sports this technology, allowing you to circumvent cords altogether.
Thank you. I guess I remember something like that, saw it at Walmart. Never had a phone that could use it so I just gave it a cursory glance and then forgot about it. So the next question would be, where would we get one of these mats to charge the phone?
I have been trying to look at pictures, but does the Nexus 4 also have a microusb port? I use microusb in my car.
Google will be selling a wireless charging puck.
Gallery: Wireless Charging Orb for Nexus 4 photos | The Verge
It has a standard microUSB port. The wireless charger is separate. Hopefully it's not too expensive.
Hopefully everyone jumps on board with this so it becomes a standard across Android.
Yeah, I like the idea of wireless charging. If the battery life is as good as they say, then I wouldn't have to plug it in while out working. My current phone (LG Optimus M+) needs to be plugged in while I'm working just to have juice at home in the evenings.
Luckily for us this is already a standard. It's called the Qi (pronounced chee) standard, you can buy any charger in this standard and it'll work with the Nexus 4.
Engadget tested it with the Nokia Lumia charger and said it worked fine.
If your super keeno, you can find a list of compatible products on WPC's website
Products - Wireless Power Consortium
Yeah I had heard it was on the Qi standard. Is there any wireless charging products out there that aren't Qi or did everyone get onboard with it?
Also is the magnetic part of it strong enough that I could mount a Qi charger in my car and have it hold up the phone as I drive? I'd really like to do that.
I don't like the idea of more EMF around me.
Has anyone been able to determine if the Palm TouchStone is Qi compatible? it's not listed, but it's so old that it seem unlikely that anyone would bother getting it certified. Right now you can buy one online for about $7.
The Palm TouchStone is NOT compatible. They use different mechanisms.
See here
Oh well. I actually did some googling before I asked, I should have searched this site a little more first.
Thanks for the info and link.
No, no, it's good other people can know now, we don't want a load of wasted money going around do we?
Will it work through a case?
I gave it a Google and have found mixed views.
Take a look at this Will wireless charging work with Lumia 920 if it has a protective case | Windows Phone Central Forums and read the various accounts. That's a Nokia Lumia conversation, but they work in exactly the same way.
What I do know is that this Nokia charger seems to work despite having material and cushioning between the charger and the phone
I would think it depends on the thickness of the case. A silicon case (probably fine) a thicker one would depend.
It depends highly on the distance and the material.
Wireless charging is done through induction so certain materials would likely block it, and it probably works only on a very small scale so thicker cases would interfere. If you luck out on both counts, it'll work.
Probably has to be noted that the further away from the induction coil, the less efficient charging will be. Whilst this won't matter on cost really as phone charging uses a tiny amount of electricity, it will make charging a lot slower
