Help Wireless charging
ckali7
Got my new (to me) Note 10.1 on the way after finally winning a eBay auction. I'm really looking forward to a native Android device coming from a rooted HP Touchpad running CM 9. But, one of my favorite things about my old Touchpad was the Touchstone charger. HP really got that part right, wireless charging is the only way to go! So, I'm wondering if anyone has figured out a way to do this on the Note?
Thanks guys! Lots of help here.....Maybe I should ask this over in the Razr forum.....At least folks there will respond to a post!
I find that people will only respond if they some info that can help you, and usually very quick. As it would be pretty pointless if all members here sent you a reply saying "Sorry, can't help you with this problem mate etc etc"
Of course try other sites they might have someone with the same issue.
My personal take on what you are asking is that I think the wireless charging you mention would be a hardware issue built in to the tablet, and as far as I am aware we don't have that the note, never heard it mentioned before.
Anyway I hope you find the answer.
Dave T
I've never really seen the point, it's just not that big of a deal to plug a device in rather than set it on a mat.
In other words, I can't help you with that.
If you've ever had it you would quickly change your mind. I felt the same way you do until I got the charger for my Touchpad. It's just so much easier than fumbling with a wire. Especially on the bedside table at night.
Would be great, if not for the fact that the mat for charging is usually completely not portable. Defeats the purpose for me.
