Root Wireless N Connectivity?
we350z
I can only connect to my router's (Cisco-Linksys E4200v1 running dd-wrt) NG-Mixed radio running on channel (11 - 2.462 GHz. / 20 MHz Channel Width / AES) not the 5Ghz N-only channel (161 - 5.805 GHz. / 40 MHz Channel Width / upper Extension Channel / AES).
I can get max 6mbps connection speed. Anyone able to connect at N speeds?
Hmm my phone is connecting at 54mbps to my wireless router
Netgear WGR614V10 channel 6
Doesn't seem to connect at 150mbps, but my internet isn't that fast anyways
I had the same problem. I couldn't connect to the 5 ghz UNTIl I added tiwlan.ini to my etc/Wi-Fi folder. I used the 3g turbo charger,in it is the Wi-Fi after burner Witch uses tiwlan.ini to operate on 5ghz frequency.
Tried this - doesn't seem to work for me. I can connect with my Galaxy Nexus no problem. What 5Ghz. channel are you using?
Where did you get your tiwlan.ini file from?
