Help wireless stopped working
downey667
So now my phone has decided to not have it's wifi work anymore. it just says error whenever i click it. the same goes for wi-fi hotspot. Does anyone know how to fix this or has it happened to anyone else?
Is device able to establish wifi connection or just tries to scan/connect (assuming that connection settings are correct and wifi network is on)?
Have you tried deleting the connection details and re adding?
Cannot access these setting unless wifi is enabled...
(unless I'm missing something)
Any help would be greatly appreciated as I'm about to head OS for a few weeks and returning for warranty isn't an option. :(
xoxo
I get this occasionally, it's normally sorted by switching on and off/removing the battery for a few secs.
If it's happening all the time, the only thing I can suggest is a factory reset.
