why not just use the stock mobile WiFi hotspot function?
I've been thinking about that. If we turn it on, does AT&T know we are tethering, and will they charge us?
I didn't use the Wifi hotspot on my old Evo very often. It's just handy to have.
I don't think it would work even if you turned it on if you haven't paid for the service.
Wireless Tether works flawlessly for me on my g-note II
http://forum.xda-developers.com/showthread.php?t=2006462&highlight=tether
If this link helps you, make sure to thank the dev.
Sprint's GN2 does not have it.
That's crazy. So when you go into settings --> More settings, you do not have "Tethering and portable hotspot"? If not you can always use FoxFi but keep in mind if you do not have a tethering plan, they may automatically change your data plan to one that allows tethering and charge you for it without warning.That's crazy. So when you go into settings --> More settings, you do not have "Tethering and portable hotspot"? If not you can always use FoxFi but keep in mind if you do not have a tethering plan, they may automatically change your data plan to one that allows tethering and charge you for it without warning.
