Help wireless tether help
junebogey
can some1 plzzzz help me i downloaded the newest version not from the market from google and i can find it when i search for a connection but it wont connect to the internet its limited tried computer and ps3 also it i tried the second to newest
If your on a 2.2 ROM, it most likely won't work. Not many (if any) have it working.
Worked fine on my stock 2.2 (installed via root) and on Baked Snack 1.7 with both kernel 6 and kernel 5.
Use Sitlet's link above to get the app from Google and you should be fine.
