Here's a list of the Wireless Tether for Root beta's . I would start w/ the first and work my way down until you find on that works . No guarantee but it won't hurt 2 try .
Downloads - android-wifi-tether - Wireless Tether for Root Users - Google Project Hosting
One more thing , some will work as Ad-Hoc and others will work as true wifi . I use the beta 11 and both work on my Prevail .
If only if there was a way we're it is automatically off every time we reboot without having to go back in that would be awesome.
Oh and also the hotspot only works with 3G not Wi-Fi. So whenever you start your phone for hotspot 3G will only work.
Hey I also have a boost Marquee running ctmod 3.6.5 with 1.5 hyper kernel same problem wifi signal appears on my computer but it wont acess the internet
works fine. Just because your computer says it's not connect doesn't mean that it isn't:smokingsomb:
I gotta get help somewhere because I'm pretty sure I've tried everything. I just tried "wireless tether" and it connected but still no internet transferred. It does the same as the native CTmod hot spot. I'm definitely getting nothing but adhoc networks. I wish it was some sort of illusion but it's not. I keep thinking it might be a hardware issue but it just doesn't seem to be.
Just a heads up. If you bars graph on your computer has the yellow icon saying it's not connect, it lies sometimes. Mine always says that I have no Internet connection but it is connected andworks fine. Just because your computer says it's not connect doesn't mean that it isn't
The hot spot does that on all of my computers. It'll give the icon says that it has no Internet connect but it actually is connected and works very weii.
