Root Wireless Tether only Wireless B on Eris?
I have an Eris that I rooted with Eris 1 Click and now use Wireless Tether for Root Users. It works well but I can only get it to run using Wireless B and not G.
Also some of my devices will not find it; such as another Eris that I have or our PS3.
Please help.
Please help.
Consider that the phone uses 3g speed which is about 1.5 megs down. There is no reason for the phone to have anything above an 802.11b wifi hardware installed so I don't believe you'll be able to connect as g. Also, when using wireless tether you are setting up an adhoc network which from what I've heard the PS3 and other Erii will not support.
The other Eris will support it but it needs to be rooted.
