Hanneman1011
I have been looking around and seen that a bunch of you have had a problem with tethering and I had a slight problem with mine, If you have just switched ROM's and your tethering is not working at all, Download this and save to your sd card under the android.tether folder. Now if you had the problem that I had, I would connect to my computer but it would say that I do not have internet access. What happened on my phone was that The phone shut off the Network, To turn on the network Just Hold down power button while the phone is on and Select the bottom choice.
