wireless tether problem
hmmm im at a loss, try removing all your superuser permissions and try re alloying it to use root access, im able to get the same error if i block wireless tether from root accesses
I flashed another ROM (other than Fresh) and Wireless Tether works fine. What gives with the Fresh ROM I wonder?
Aloysius 2.1 - except that sometimes it freezes when turning it off. But it works when you turn it on... It's a start, right?
I was having a problem to get wireless tether to work with rooted stock 2.1, and I followed the workaround suggested by a guy here
which is to start wireless tether and then turn off mobile network and turn it back on
Hey everyone....first post on here. Running Fresh 2.1.2 and I also installed the SU patch. But, when I try to start tethering, the SU opens, but I just get a black screen with nothing asking if I want to allow the app SU privlages and it freezes there until I get the box that asks if I want to FC or keep waiting. I have wiped dalvik and did many reboots and still same results. I was getting ready to update Tether, but from what I read, it's best to stay at version 1.60. Any help on this is greatly appreciated.
Please disregard.....I realized I did not have USB debugging turned on. Works like a charm now.
