ok so, in addition to the wireless tether that came with my rom i need aNetshare, or something similar?You need a wireless tethering app. I use aNetshare. Turn on Wireless tethering in the app you are using. On your laptop, open up your Wireless network preferences and search for a network. You should be able to see your Eris from there and connect.
K, cause i tried searching for my eris through my laptops search wireless connections and it couldn't find itOh no, if there is already a Wireless tether app on your ROM, you do not need to download another app.
K, cause i tried searching for my eris through my laptops search wireless connections and it couldn't find it![]()
cool thanksTry another app like aNetShare. I'll PM you the apk.
By the way, what ROM are you using?
ive heard that if you turn off access control that it will work. Maybe try that and see if it works. Make sure you have the newest wireless tether out, I was having problems and found out it was because i had the older version of it.
Yes it will. My Eris provided wifi for my friend's laptop and iPod Touch (he even jailbroke his iPod while we were on the interstate, lol).Still not working. And will the Wireless Tether provide wifi for an IPod Touch?
Cool. If only I could get it to work now.Yes it will. My Eris provided wifi for my friend's laptop and iPod Touch (he even jailbroke his iPod while we were on the interstate, lol).
Can you describe the problem you're having?
the only problem i have with WiFi Tether is that it really makes my
phone get warm, really warm. does aNetShare have this some problem?
does aNetShare use less battery than wireless tether?
bc for me wireless tether is pretty bad.
i run tazz and have great battery i can very very easily get through a long day and 2 days if i dont use it too much.
over the weekend i was calibration the battery and it was sunday and i didnt want to stay up late running it down until i could put it on the charger to be ready for monday so i turned wireless tether and it only took like 4 hours (give or take) to run it down completely.
so is aNetShare any better?
