Root Wireless Tether ?
Are the people that claim to have the 4g hotspot working also the wireless tether app working. Are you guys using the User agent switcher? Or is it just working by default as expected with no modifications?
Mine works always has i have the $50 plan, running the Base de-odexed ROM.
I tether my a500 all the time.
I turned it on in settings and used the app to change the password.
Only known devices that dont need to be modified are other android devices or video game consoles, others you need to change User Agent or use a VPN
make sure you re-set your lan settings to the ones given in the fox fi settings-unless you use that proxy-it will not connect
