Help wireless tethering causing me to lose internet...
potterdood
Ok, I am rooted and have the wireless tethering app installed. @ 1st it worked pretty good, but here recently it will work for a few minutes then cause my internet to go out for like 30 min or so...but when I tether with pdanet it works for hours with no problem ever. what am I doing wrong when I wirelessly tether to make it stop working, when it stops working, my mac is still connected to the wifi but won't transmit anything.
my internet works through pdanet though, so you're saying delete wireless tethering n re install? where r those drivers?
I'm not exactly sure with Mac, but Windows, you can look up hardware and just delete the hardware from the computer "which deletes the drivers" as soon as they drivers delete, the computer should automatically detect and offer to reinstall the drivers for you. You don't have to find them online.
I am guessing Mac has some sort of hardware manager that does the same things.... but then again, it's made by apple so I'm not quite sure.
ok I read 2 things on the wireless tether app when I re installed it, it says requires root( which I have) and it says requires netfilter-enabled kernel. well I'm using the stock htc kernel, do you think that's my problem, I went back to the stock kernel bc I thought we might be getting 2.2 soon and wanted to update asap instead of waiting til I got home. thanks for your help thus far btw.
