I'm having a wireless tether problem as well. When I had the Droid Eris, it would connect on my macbook as a regular wireless network with no problem. Now with the X, it only connects as a Wireless "Device" and I also have problems with the 3G connection dropping every 5 minutes. (Battery Saver is set to shut down connections after 1 hour, so that's not the issue)
