hey,
when i bought my note 3 it's appear to me that there is Wlan instead of Wifi and told my friend about this issue and he solved to me but when i made factory reset it's appear "Wlan" again
so how can i switch to wifi
I have an old Samsung S4 and that icon is labeled "wifi". I've never seen it labeled as WLAN, although I agree WLAN (wireless LAN) logically means the same thing.
I just want to double-check the question from op, who said "it doesn't work". Which of the following two choices is the problem you're trying to solve:
A - When you push the icon, it toggles wifi as expected. But you just don't like the label.
OR
B - When you push the icon, it doesn't toggle wifi.
Either way, try pushing the icon in upper right hand corner of the screenshot to see if there are alternate icons that you can put into your pulldown.
