Root wont connect to my Clear wifi router
maxwell12
I have Clear internet and my optimus elite wont connect to the router. ive talked to customer support and tried everything they said and it still doesn't connect. my phone connects perfectly fine to any other network but just not Clear. also every other device I have connect to the wifi except my optimus. please help.
Strange. Mine won't connect to my Buffalo running OpenWrt but will connect to others at work. Other devices connect fine to my router. Which ROM are you running? I'm running Sleipnir.
Several different Virgin Mobile phones won't connect to the Clear Hub Express model GTK-RSU131. I don't know all the makes and models that won't, but I do know that the Clear Hub Express is not listed as WiFi Certified by the WiFi Alliance. Since it isn't, that is a BIG problem regarding WiFi compatibility! The Virgin Mobile LG Optimus Elite isn't Certified either, so again BIG problem with compatibility! Always buy WiFi Certified devices to avoid connectivity issues.
