Done what?Have done exactly that but after about 10 seconds the connection disappears and the battery shows no longer charge? Stumped![]()
Then install SEUS, run it, connect in flash mode when prompted, continue.Yes, can get it into flash mode (constant green light after back and usb insert) but nothing seams to happen after, cheers.
You'd said it had a constant green light which would indicate it's working fine. Take the battery out for 10 seconds and try again.Tried but the usb seems to disconnect itself??.
