Help Won't load sd apps
mal93
Hi, i just wiped the cache and the dalvik cache via recovery. i'm using app2sd to move application 2 the sd card. I'm on froyo 2.2 on optimus one.
i'm rooted and with custom recovery.
After the wipe the application on the launcher have the default android icon and when i click on them it says application not installed. the applications on sd are not listed in the appdrwaer.
how to solve?
yes, i tried, the settings menu freezed and i need to close every time i tried.
i started the amonra recovery and formatted the card and reisnatlled everything. now i works fine and there a lot of space
thanks for reply, solved
