Did you take a nandroid first? You should always do that before changing anything in /system.
I suspect the first boot might be slow, as it will be copying a lot of stuff to sd-ext. So give it time. If it's still hung after 20 minutes though I think you can assume it's not worked.
You can remove the int2ext script by going into recovery and reflashing the ROM. Don't worry about a factory reset, but I'd probably wipe cache and dalvik to be tidy.
Whether that's enough to get you going will depend on what the int2ext has managed to do. If it won't reboot after that you may need to do a factory reset, because that would imply it got as far as messing up the apks and user data on your phone badly.
Did you try using the a2sd that's built into the MildWild ROM, or did you just install int2ext first?
