Help Won't reboot after root
baxt1412
Can't post links or anything, but followed directions on xda... thread called
"[NC][1.2][1.3] ManualNooter 4.6.16"
Anyway, used the WinImage to make the CWM bootable card
copied over the zip files for Manual Nooter 16 and 18
Inserted card into my Nook Color with stock 1.3 software (or however you call it)
Plugged into computer (It turned on)
Ran through the directions, ran the zip files (running 18 first, then 16)...
Removed card
Rebooted through the CWM
Now it just keeps cycling through this boot screen...
writes out "nook color" in white outlines, then the "nook" part disappears, replaced with the B&N "n" and the color part displays a rainbow of animated color
little android icon in the bottom right
Not going anyway
Have tried rebooting a few times with and without card in slot.
Help me out!!?
