I've tried searching guys, haven't found anything (but please point in the right direction if you know where).
So after the umpteenth time bricking my phone after trying stuff, i ended up doing an Odin restore, and it seemed to work fine. But when I was going through the process of rooting again, I noticed the settings (to enable debugging mode) wouldn't save between boots.
Turns out, nothing will save. Settings, texts, you name it. Wondering if you guys can help out?
Since the odin restore, the only thing I've tried is loading JT's rom, which didn't fix the issue.
