Help Won't turn on or even charge !! ( Red LED flashing when charging )
imAzew
Hello.
im here because of my lg g3 not working with a red flashing led when i try to charge for some reason + it wont even charge.
the phone got drained out of battery it wouldn't turn on again.
WELCOME TO ANDROID FORUMS imAzew !
Sorry to hear about your battery/charging issues.
Often when a battery is fully drained (avoid if at all possible),it can take quite some time to get it to take/show a charge.
24 hours isn't unheard of,but,admittedly on the extreme end of the spectrum.
I suggest leaving the phone plugged-in w/a good charger for up to 24 hrs (the one that came w/the phone is sufficient).
If at that time it's still not charging,the next step I'd take is visiting your service provider & see if they have a battery you can troubleshoot with.
thank you for your response sir !
i will try to charge it up to 24hrs
and i will reply back with what happened :)
its been 24hrs
and nothing happend !
Absolutely,hope it's just a bad battery.
Please keep us posted on your progress :thumbsupdroid:..............
Can you pull the battery and make sure all of your battery connections are straight and not bent?
Also, please confirm the battery isn't bulging
