Root Won't Update to 45.4.13, need build.prop dump
matchadb
Hi, I need help. I rooted with Photon Torpedo a while back, and everything was fine. I want to update (despite the lockdown warnings) from 45.3.6 to 45.4.13 but the update fails every time, even after a factory reset of the device. Pressing both volume buttons when I see the "!" Android gives me the error, honestly, too fast for me to read, but I'm assuming it is the build.prop problem others have had. I don't have a backup of build.prop because of the factory reset, so I'm wondering if anyone can dump the content of the build.prop file from a device that has 45.3.6 so I can successfully update to 45.4.13. Make sense? Other solutions welcome, and I'll just dump my build.prop here in case anyone knows of any small thing that can be changed to allow the phone to update, and I'll just push it back to the device. Thanks in advance.
tl;dr follows - build.prop (links removed, new user restriction):
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=4.5.1A-1_SUN-198_6
ro.build.display.id=4.5.1A-1_SUN-198_6
ro.build.version.incremental=CM
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.4
ro.build.date=Tue Sep 20 02:34:36 EDT 2011
ro.build.date.utc=1316500476
ro.build.type=user
ro.build.user=dnt648
ro.build.host=fl36bld22
ro.build.tags=release-keys
ro.product.model=MB855
ro.product.brand=sprint
ro.product.name=moto_sunfire
ro.product.device=sunfire
ro.product.board=sunfire
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=motorola
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=tegra
# ro.build.product is obsolete; use ro.product.device
ro.build.product=moto_sunfire
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=sunfire-user 2.3.4 4.5.1A-1_SUN-198_6 CM release-keys
ro.build.fingerprint=sprint/moto_sunfire/sunfire:2.3.4/4.5.1A-1_SUN-198_6/CM:user/release-keys
# end build properties
# CDMA RIL ----------------------
persist.ril.uart.flowctrl=1
persist.ril.mux.ttydevice=/dev/ttyHS3
#IKXETNA-176: Increased number of mux channels to include M2M.
persist.ril.mux.noofchannels=10
persist.ril.modem.ttydevice=/dev/ttySPI0
persist.ril.modem.mode=1
persist.ril.features=0x0C
#Commenting out the rild path here. Check sunfire.mk
# Comment the following line for use with Multimode or LTE RIL
# rild.libpath=/system/lib/libmoto_ril.so
# End of CDMA RIL --------------
# LTE RIL ----------------------
# Comment the following line for use with Multimode or CDMA RIL
# rild.libpath=/system/lib/lib-mot-lte-ril.so
# End of LTE RIL ---------------
# Multimode RIL ----------------
# lte_ril.libpath=/system/lib/lib-mot-lte-ril.so
# cdma_ril.libpath=/system/lib/libmoto_ril.so
# ril.rat=LTE
# Comment the following line for use with CDMA or LTE RIL
# rild.libpath=/system/lib/moto-ril-multimode.so
# End of Multimode RIL ---------
ro.hdmi.mirror.enable=false
ro.hdmi.default.app=
hw.overlay.path.config=
ro.mot.ril.danlist=611,*611,#611
persist.ril.ecclist=911,*911,#911
# This defines the max event window manager can
# handle in 1 s. We may adjust this # for performance
# reason later
windowsmgr.max_events_per_sec=70
# for larger screen support
# 4.3" WVGA == 216dpi
# 4.3" qHD == 256dpi
ro.sf.lcd_density=240
dalvik.vm.heapsize=42m
# required for UDD backup tcmd
ro.mot.hw.calibratedImager=1
# ro.cdma.homesystem:
# List of the icon indexes for Enhanced Roaming Indicator.
ro.cdma.homesystem=64,65,76,77,78,79,80,81,82,83
# Default network type.
#BEGIN Motorola, dfgr73, IKSUNFIRE-2266 Preferred Network should be set to Automatic
# 7 => GLOBAL.
ro.telephony.default_network=7
# END IKSUNFIRE-2266
ro.url.legal=LINK
ro.url.legal.android_privacy=LINK
ro.config.vc_call_vol_steps=7
# Feature 33857 support DualMode switch, UMTS/CDMA
# This does not apply to Etna as it is not a Global phone.
# IKXETNA-337 turned off this flag.
# Enabling the flag for sunfire.
ro.mot.FTR.33857=true
# without this property, the lock screen would take global phone as UMTS
# block user to operate before setup
keyguard.no_require_sim = true
# set phone mode for lte sim ui
#ro.mot.phonemode.vzw4gphone=1
# This is necessary for framework to support
# the LTE and eHRPD capability.
#ro.mot.lte_on_cdma=1
ro.cdma.home.operator.numeric=310120
ro.cdma.home.operator.alpha=Sprint
# Indicate carrier OTA SP number schema
# refer to frameworks/base/telephony/java/com/android/
# internal/telephony/cdma/CDMAPhone.java for the schema:
ro.cdma.otaspnumschema=SELC,1,80,99
# BEGIN Motorola, a20763, 1-Dec-2010, IKMAIN-7617
# write cdma MIN to property for VVM use in GSM/UMTS mode
persist.radio.cdma.min = 0
# true Horizontal VVM is preloaded, not allow to install standalone version of
# VVM from Android Market
# false Horizontal VVM is not preloaded
ro.HorizontalVVM=true
# END IKMAIN-7617
# The OpenGL ES API level that is natively supported by this device.
# This is a 16.16 fixed point number
ro.opengles.version = 131072
# our HTML browser (not WAP browser ) does not need to specify UAProf URL
ro.mot.hw.uaprof=LINK
# Enable HAC to also display Call Setting Menu Option.
ro.mot.hw.HAC=1
# Motorola, a19622, 12/28/2009, IKSHADOW-204 / Location Settings for android
# Property to set enabling state of the location privacy setting feature.
# Motorola, a19622, 03/16/2010, IKSHADOW-2141 / Disable feature 33067
#ro.mot.settings.locprivacy=1
# ERI feature
# 0 OFF
# 1 ON
ro.mot.eri=1
# Motorol,a6889c,02/Feb/2010,IKSHADOW-619
# Proximity Sensor feature
# 0 disable
# 1 enable
persist.mot.proximity.touch=1
# BEGIN Motorola, a22976, 25-Feb-2010, IKSHADOW-702, FID 31841
# VZW Requirement Specifications: NETWORK BASED PLUS CODE DIALING
# 0 disable
# 1 enable
ro.cdma.nbpcd=1
#Proximity sensor debounce time
mot.proximity.delay=450
# disable touch below 60 pixels
mot.proximity.distance=60
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 45
# BEGIN Motorola, nfjb73 23-jun-2010, IKMAIN-624
# this is for feature 33860, when phone is activated, the cdma mdn is written.
persist.radio.vzw.cdma.mdn=
# END Motorola, nfjb73
# BEGIN Motorola, e50202, 3-Sept-2010, IKSTABLETWO-7041, default Mobile Hotspot is on
ro.mot.mynet=true
# END IKSTABLETWO-7041
# BEGIN Motorola, a22976, 20-Oct-2010, IKSTABLETWOV-3218
cdma.nbpcd.supported=false
# END IKSTABLETWOV-3218
# BEGIN Motorola, a23250, 08-Nov-2010, IKMAIN-7258
ro.mot.bindervm.config = 72
# END IKMAIN-7258
#BEGIN Motorola, 30Jan2011, w19837, IKSUNFIRE-215, Feature ID: 35761.
#[sprint tv transport protocol support]
sprint.mm.http.proxy = LINK
sprint.mm.http.port = 8085
sprint.mm.rtsp.proxy = LINK
sprint.mm.rtsp.port = 554
sprint.mm.network.type = unknow
sprint.mm.nai = unknown
#END IKSUNFIRE-215
# For docked touchpad keyboard map
android.keylayout.evfwd=/system/usr/keylayout/evfwd.kl
android.keychar.evfwd=/system/usr/keychars/evfwd.kcm.bin
# BEGIN Motorola, 19Mar2011, vcnw83, IKSUNFIRE-423
slate.keyevent=false
slate.penevent=false
# END Motorola, 19Mar2011, vcnw83, IKSUNFIRE-423
# USB modes allowed for UI and switching
ro.ngp_available=1
ro.modem_available=0
persist.mot.usb.mediasync = 1
# Motorola, IKHALFMWK-3, w001091
# Feature 32711, deep sleep mode support
#ro.mot.deep.sleep.supported=true
# BEGIN Motorola, 3/23/2011, a21739, IKSUNFIRE-465
ro.mot.phonemode.numsignalbars=6
# END IKSUNFRE-465
#BEGIN Motorola, 4/21/2011, gqkp64, IKSUNFIRE-716
# turn it on since sunfire is a global phone
# this is for feature 34386, other features for vzw global phone
# could use this property too. IKMAIN-732
#1 this is verizon wireless globle phone
#0 this is not verizon wireless globle phone
ro.mot.phonemode.vzwglobalphone=1
# END IKSUNFIRE-716
#BEGIN Motorola, nfmq37 27Apr2011 IKPAXSPRINT-952, a21269 08/01/2011 IKSUNFIRE-3199
# Enable RDC Feature
# "ro.rdc.enable" is a bitwise flex value:
# bit 0: indicating RDC uploading function
# bit 1: indicating RDC lifetime metrics function.
# bit 2-7: reserved.
# Make sure ro.rdc.allow_wifi_upload, ro.rdc.no_of_domain and ro.rdc.whitelist_domain1
# are properly changed/finalized when ro.rdc.enable=1
ro.rdc.enable=1
# Allow Upload of RDC Metrics over WiFi
ro.rdc.allow_wifi_upload=1
# RDC Whitelist
# while adding new domain increment no_of_domain &
# add element ro.rdc.whitelist_domainX, where X is
# domain no
ro.rdc.no_of_domain=1
ro.rdc.whitelist_domain1=.att.com
#END IKPAXSPRINT-952, IKSUNFIRE-3199
# ADDITIONAL_BUILD_PROPERTIES
persist.ril.mux.retries=500
persist.ril.mux.sleep=2
ro.kernel.android.ril=yes
ro.config.ringtone=EtherShake.ogg
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.default_usb_mode=0
ro.media.enc.aud.fileformat=qcp
ro.media.enc.aud.codec=qcelp
ro.media.enc.aud.bps=13300
ro.media.enc.aud.ch=1
ro.media.enc.aud.hz=8000
ro.com.google.gmsversion=2.3_r6
ro.config.sync=no
ro.browser.useragent=0
ro.config.sync=no
ro.media.camcorder.720p=mp4,h264,30,12000000,aac,128000,44100,2
ro.media.camcorder.d1NTSC=mp4,h264,30,6000000,aac,128000,44100,2
ro.media.camcorder.vga=mp4,h264,30,4000000,aac,128000,44100,2
ro.media.camcorder.cif=mp4,h264,30,1500000,aac,128000,44100,2
ro.media.camcorder.qvga=mp4,m4v,15,225000,amrnb,12200,8000,1
ro.media.camcorder.mms=3gp,h264,15,128000,amrnb,12200,8000,1
ro.media.camcorder.mmsres=qvga
ro.camcorder.zoom=true
ro.media.capture.shuttertone=0
ro.camcorder.videoModes=false
ro.media.panorama.defres=2592x1458
ro.media.panorama.frameres=960x540
ro.telephony.call_ring.multiple=false
ro.telephony.call_ring.delay=3000
ro.com.google.clientidbase=android-motorola
ro.com.google.clientidbase.am=android-sprint-us
ro.com.google.clientidbase.yt=android-sprint-us
ro.com.google.clientidbase.ms=android-sprint-us
ro.com.google.clientidbase.gmm=android-motorola
ro.url.legal=LINK
ro.cdma.data_retry_config=default_randomization=2000,0,0,120000,180000,540000,960000
ro.mot.setuptype=2
ro.media.camera.focal=3378.6,3378.6
ro.media.camera.principal=1296.0,729.0
ro.media.camera.skew=0.0
ro.media.camera.distortion=0.0,0.0,0.0,0.0,0.0
ro.media.camera.calresolution=2592,1458
ro.setupwizard.enable_bypass=1
ro.mot.internalsdcard=1
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.mot.dpmext=true
ro.com.google.clientid=android-motorola
ro.url.legal=LINK
ro.build.version.full=Blur_Version.45.3.6.MB855.Sprint.en.US
ro.mot.hidden_keyboards=evfwd
Didn't see this until now. But if you were rooted and trying to take an "official" update, my understanding is that you'd have to un-root in order for the udpdate to work.
