Hello everyone
I've seen a lot of complaints about the charging port being placed on the bottom so you can't charge the phone while you use the kickstand in landscape mode.
I found what I consider to be an acceptable work around. Place the phone the other way, so the kickstand is parallel with the table and the charging port is on the top. Then place a pen under the kickstand. It's not as sturdy as the other way (obviously) but it gets the job done.
The phone is too heavy if you don't use a pen (or whatever) underneath the kickstand and it will fall flat. The pen causes the phone to be more upright, and therefore less weight is on the stand and it can hold it up.
Anyway, hope this helps someone.
