Work Email on my prevail
I would like my work email on my stock Prevail. Is this something I can do on my own or do I have to give my phone to our IT Dept? Thanks!
OK. Stupid question #2. What info do I need? Or I will try to search for how to do it and what i need if I get a min. Its pretty busy right now here
Domain Name:
User Name(if differ from email):
Password:
User Email Address:
Password for Email (if Different From User Name Password):
Exchange Server Address:
Got a min and found this on the Samsung site. it seems simple I know most if not all that info myself or know where to find it. THANKS!! :)
Synchronizing Your Corporate Account
1.Press the Home key
2.Press the Menu Key
3.Tap on Settings
4.Tap Accounts & sync
5.Tap Add account.
6.Tap Microsoft Exchange ActiveSync.
7.Follow the onscreen prompts to create your new Corporate email account.
8.Any changes or updates to your Corporate/Outlook account are automatically updated to your device.
To configure the Corporate management settings:
3.Tap on Settings
5.Tap within the Corporate account field to reveal the account's synchronization settings
screen.
6.Tap the parameters you wish to synchronize.
◦Account settings allows you to configure the current email account settings such as:
I got it done. All I needed was one pc of info from our IT dept. Cool now I can be bothered 24hrs a day instead of only 12hrs a day. IDK how good of an idea this this LOL.. Its gonna save my rear and put it in danger at one time or another. THANKS ANDROID FORUMS!!!!
Adding to Beginners Prevail guide.
That copy paste was choppy, I was using the mobile skin at the time. Here it is again.
  1. Press the Home key
  2. Press the Menu Key
  3. Tap on Settings
  4. Tap Accounts & sync
  5. Tap Add account.
  6. Tap Microsoft Exchange ActiveSync.
  7. Follow the onscreen prompts to create your new Corporate email account.
  8. Any changes or updates to your Corporate/Outlook account are automatically updated to your device.
  3. Tap on Settings
  5. Tap
    screen.
  6. Tap the parameters you wish to synchronize.
    • Account settings allows you to configure the current email account settings such as:
      • General settings allows you to configure:
        • Account name displays the name used by the device to track the account.
        • Your name displays the name used in the From field within your outgoing emails.
        • Amount to synchronize to assign the sync range for your incoming and outgoing emails between your device and your external exchange server. Choose how many days worth of emails the Galaxy Prevail™ and server should synchronize. Choose from: One day, Three days, One week, Two weeks, or One month.
        • Default account assigns this account as the default used when sending out new emails.
        • Out of office settings Configures your out of office notifications.
        • Empty deleted items Allows you to delete your email account's trash bin remotely.
        • Sync schedule Allows you to configure your email sync schedule.
        • Email size Configures the incoming email size allowed to pass through to your device automatically without user interaction. Larger emails will have to be retrieved manually.
      • Notification settings allows you to configure:
        • Email notifications enables the device to display a status bar icon
          when new emails have been received.
        • Select ringtone assigns an audible ringtone when a new or upcoming event is pending.
        • Vibrate assigns a vibration when a new or upcoming event is pending.
      • Server settings allows you to configure:
        • Incoming settings provides access to the Domain, password, and exchange server
          parameter fields.
        • Sync contacts synchronizes the contacts between your device and the remote exchange server. A green checkmark indicates the feature is enabled.
        • Sync calendar synchronizes your exchange calendar entries between your device and the remote exchange server. A green checkmark indicates the feature is enabled.
        • Sync calendar history assigns the calendar sync period.
      • Common settings allows you to configure:
        • Add signature: Activates the email signature feature.
        • Signature allows you to create an outgoing email signature attached to new emails sent from your device
The link
http://ars.samsung.com/customer/usa...D=2&PROD_SUB_ID=557&PROD_ID=2030&AT_ID=370858
