Root Working Apps2ext_sd solution
Paul25
Hi All i thought i would post about this great app. It works great freeing up space FolderMount found HERE At the playstore PLEASE NOTE YOU MUST BE ROOTED
I have paid for the pro version but the free version still allows you to mount 3 folders to your ext_sd.
Here is the link to there own website explaining it LINK
I hope this helps a lot of you looking for a fix posed by Kitkat not allowing certain apps to write to EXT-SD.
